firstlast
10-11-2008, 11:48 PM
will 235 55 r16 tires fit on factory salad shooters?
what will fit salad shootersfirstlast 10-11-2008, 11:48 PM will 235 55 r16 tires fit on factory salad shooters? 30AnniversaryZ28 10-12-2008, 12:18 AM That's one of the stock sizes, so yes. firstlast 10-12-2008, 03:43 PM ok cuz in running 245's now. thanks for the response Injuneer 10-12-2008, 03:58 PM The "base" tire for the Z28 was a 235/55-16. If the car was ordered with the OPTIONAL Z-rated tires, you got 245/50-16's. If your PCM is programmed for the 245's, running the 235's will cause the speedo to read 2% lower than actual speed. 6SpdLT1Z 10-12-2008, 09:32 PM Its safe to mount on the wheel, but your speedo will be off. firstlast 10-12-2008, 11:51 PM thats fine my speedo is off by 5 mph anyways so it will even it out | ||
