TJ Chapman
10-11-2008, 03:16 PM
im thinking not but wanna double check: will a set of M/T radials this big fit stock wheels? on a stock suspension? on a 99 Z?
295/50/16TJ Chapman 10-11-2008, 03:16 PM im thinking not but wanna double check: will a set of M/T radials this big fit stock wheels? on a stock suspension? on a 99 Z? Injuneer 10-12-2008, 03:54 PM I looked at the M/T website, and did not see that size shown on either of the ET Street Radial size charts. But the "links" for the two different tread patterns for the ET Street Radials both go to the same size chart. They used to go to two different sets of sizes. I did find that size with a "search", and it appears to be the "sport compact" tread pattern, not the tread pattern used on the really sticky drag radials that are often referred to as the "world's fastest". A 295/50-15 would be a 26.6" tire, so the diameter would not be a problem. But M/T recommends that the wheel width be no more than one inch narrower than the tread width, and their 295 tires typically have a tread width close to 11", meaning you would need a 9.5 - 10.0" width for them to fit correctly. Stock wheels are only 8.0" wide. TJ Chapman 10-13-2008, 06:13 PM yeah i kinda figured but i did find this size on summit im almost positive it was the et streets but maybe i was wrong. im sticking to 255s in some drag radial make | ||
