What kind of tranny and rear end?
JackB03
10-10-2008, 09:17 AM
Im putting a 383 street/strip engine from VRE and getting some LE2's with custom cam from Elliots, in my car very soon. Im curious what kindve tranny and rear end I should go with. And with the rear-end, what all do I need? Im getting a 12 inch, but is there anything else i need back there?
Jack
12SCNDZ
10-10-2008, 12:36 PM
Are you looking for an automatic transmission or a manual?
Frank
CPT
JackB03
10-10-2008, 04:13 PM
I have an automatic....Just need to figure out what would be best for my application..
Jack
12SCNDZ
10-10-2008, 05:40 PM
If you've still got the computer in the car, then a properly built 4L60E will work fine for you. You'll have the benefit of the low (3.08) first gear, and overdrive. If you don;'t want to utilize your computer, you could go 700R4, which still has the same first gear, and O/D. If you want to buy a bunch of extra parts, then you could go TH400. It's definitely the strongest, but it doesn't have the first gear ratio or O/D that the others do.
Give me a call, if you'd like to discuss it further.
Thanks,
Frank
CPT
302-250-1202
