Blown carb gasket
Old Jan 1, 2003 | 04:10 PM
pacesetter's Avatar
Blown carb gasket
Well I took my camaro out for a spin around the block and I got on it a little bit and all of a sudden I started hearing this louding knocking sound. I was like sh*t!!!!!!!! I thought I threw a rod.... It was loud..... well I turned off the car and started it back up... heard it again... but when I gave it gas it went away so I knew it wasnt a rod....... the carb gasket in the front had been sucked in! now my question is, since this got sucked into the manifold will it be dangerous in away way? And what should I do about it? Never had this happen..... Thx
Old Jan 1, 2003 | 07:09 PM
1981zzz's Avatar
If u take your carb off u might be able to fish the pieces of the gasket out whith a piece of a coat hanger what type of carb are u running if u are using the paper type gasket u should find one that is thicker and make sure your carb is tightent to your specks good luck
Old Jan 1, 2003 | 08:33 PM
pacesetter's Avatar
Im running an edlebrock 750cfm manual choke. I will try that coat hanger thing.......... if I cant find any of the peices is it harmful that they are in the engine now?
Old Jan 4, 2003 | 04:11 PM
1981zzz's Avatar
hey hope you had some succes in geting the gasket out if you didnt get it with the coat hanger you might have to take the intake off to get the pieces i dont think it will hurt anything but its better to get a nother opinion i will check with my friend he will no for sure
1981 z28 350 bored 60 over flat top pistons 10 2 1 compresion 501 lift cam 202 valves wiht 373 posi and t10 4 speed fffffffffast
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Kawi
Sep 28, 2015 09:01 AM
Bxlt1
Sep 10, 2015 08:16 AM
