n20 timing retard question.
94GreenMachine
10-07-2008, 08:41 PM
I'm wondering when to retard the timing, when the n2o engages or at a specific rpm. I'm running a mild bolt on motor on a stock tune for the time being (until winter when it goes under the knife) and I know I don't theoretically need to retard the timing for safety reasons but want to do it anyway to see if I can't gain a little top end as well as be safer, etc. for example, I'm running an msd6 digital and a nitrous outlet dual window switch with the lt1 plate system at a 100 shot. Should I set the timing retard to activate on the first window stage when the nitrous starts at say 3000-3500 rpms or on the second switch at a higher rpm like 4500 rpms, etc.
thanks.
Ray@NitroDaves
10-08-2008, 10:51 AM
copied from LTXtech.com
Here is a diagram I made for another LT1 guy...the wire marked for the Crane ignition retard will connect to the retard wire on your MSD box also.
http://www.fquick.com/images/vehicles/full/382133881.jpg
Stroked96bowtie was correct that you will want the timing pulled as soon as the solenoids are active.
Please let me know if you have any other questions.
94GreenMachine
10-11-2008, 02:32 AM
ray thanks for the diagram it will come in handy in a couple days when the kit arrives.
