Whats the most likely source of front end noise?
Old Oct 6, 2008 | 02:37 PM
JohnD's Avatar
Squeak, that is. I know it isn't the sway bar because it has grease fittings on it and I just greased it. About all that leaves is ball joints and A-arm bushings. 87K mi. now and I replaced the springs and shocks at about 85K. Come to think of it, I wonder if it could be the sway bar end links, I changed them out to poly ones when I put in the bigger sway bar?
Old Oct 9, 2008 | 10:46 AM
JohnD's Avatar
It was the sway bar end links. I squirt of 90 wt. made it completely go away. I'll go back and use marine grease when i have more time.
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
dbrockma
Feb 16, 2015 02:56 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
