swey00
09-27-2008, 01:48 AM
I have a 98 camaro Z28 for sale. It has a motor out of an 02 TA firebird with only 42k miles on it(does not have the ls6 intake though). I purchased the car and put the motor it in about 2k miles ago.
The transmission shifts fine. The motor does not use any oil. Tires have good tread on them still. I just had the car aligned after I put the motor in the car. It has new belts on the motor. I put new spark plugs in when I changed the motor. It had 3:73 gears put in right about 2500 miles ago.
The car is not perfect by any means, but it is a solid car. It definitely needs new paint. The plastics inside the rear hatch are not mounted properly and I have not checked to see what it needs to be fixed, but they are mostly all there and look ok the way they are. The stereo cuts out when on am/fm stereo but is fine when playing a cd or mp3 cd(I will try to find another cd player before I sell the car). The rear bumper has a hole in and a small crack, I don't know how it happened, was like that when I got it(I will be trying to find another before I sell also, have a lead on one now).
I would keep the car, but I need to pay some taxes and get a more economical car because there is a baby on the way. All in all it is a good car, with a minimal amount of tlc it would be in really good shape.
Any questions, just give me call at (918)951-5658 or email me.
Thanks for looking,
Chris
swey00@gmail.com
I can deliver for about .75 cents a mile, maybe cheaper if you bought me a plane or bus ticket home.
Also, I have a comp cam($200) and the old engine($650) that can go with it if purchased with car, otherwise it will be slightly higher. The motor started knocking on and off from what I believe was the oil pump going out. It didn't do it all the time, just randomly, but it was definitely a knock.
http://ls1tech.com/forums/attachment.php?attachmentid=145583&d=1220084362
http://ls1tech.com/forums/attachment.php?attachmentid=145584&d=1220084362
http://ls1tech.com/forums/attachment.php?attachmentid=145585&d=1220084362
http://ls1tech.com/forums/attachment.php?attachmentid=145586&d=1220084362
http://ls1tech.com/forums/attachment.php?attachmentid=145587&d=1220084362
http://ls1tech.com/forums/attachment.php?attachmentid=145588&d=1220084399
http://ls1tech.com/forums/attachment.php?attachmentid=145589&d=1220084399
http://ls1tech.com/forums/attachment.php?attachmentid=145590&d=1220084399
http://ls1tech.com/forums/attachment.php?attachmentid=145591&d=1220084399
http://ls1tech.com/forums/attachment.php?attachmentid=145592&d=1220084399
Thanks for looking,
Chris
swey00@gmail.com
