Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Sweet lt4 a.f.r.top end. Also nx maf system
Old Sep 15, 2008 | 09:45 AM
BIGCOWL-IMP's Avatar
I`m going to try to sell this all at once first. If i can`t sell it as 1 unit then i will part out so make offers.
LT4 AFR 220 heads with T&D shaft mount rockers & $300 valves springs. Flow 319@ 600 Also comes with polished alum. sheet metal valve covers.
Ported LT4 intake with ASM mono blade tb. with f.m.s 42# injectors.
If you buy the complete heads and intake i will throw in a comp cams solid roller cam and Diamond push rods for free
I have right about $5,400 invested with all the port work and parts. I`m thinking $3,200
Also have a ls1 or lt1 nx m.a.f. system with the second stage with purge.
Second stage has never been used.
I`m going to keep the bottle and long line from trunk to engine bay. I would like to keep this system together because its all wire up together. When i remove it i will label the wires for easy install. I will also include the full throttle switch thats on the lt1 style tb.
Could also come with custom lt1 fuel rails with an fittings with braided lines.
It has -8 in and -6 out. Could also come with Aeromotive feul pressure regulator and y block with all braided lines. Price depends on what you want.
Heres a couple pics but its a mess as i just installed everthing that day.
Old Sep 19, 2008 | 07:44 AM
limige's Avatar
hey boss, i may be interested in the TB and injectors, shoot me a price if you want to split that stuff up.
Old Sep 23, 2008 | 10:59 PM
I would really like to sell the heads first if i can`t sell the heads i might just use everything sorry.
Old Sep 27, 2008 | 05:32 AM
Mogulskierk2's Avatar
x2 on the tb, pm a price if still avail please
grgguy
17
Feb 23, 2015 07:57 PM
Collector Car
Jan 5, 2015 10:58 AM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
