Turbo Flutter
Old Sep 14, 2008 | 10:32 PM
IROCThisZ28ForLife's Avatar
Question Turbo Flutter
Is this bad? Also, whats the difference between turbo flutter, and flutterdump???
I know flutterdump is the BOV releasing a bit to late, is this different than turbo flutter, or is it the same? (sorry for the run on sentence)
In this link at like 22, and 40 seconds (also throughout the video) you hear what sounds like flutter...I always thought this was awesome, and only heard one Camaro that made this sound...Is this bad though?
If so what causes a)turbo flutter, and b)what causes flutterdump?
http://www.youtube.com/watch?v=Zrzq89y5K80
Old Sep 14, 2008 | 11:07 PM
LT1 POWR's Avatar
In the diesel word that is called "turbo bark" and it is bad for the turbo, but I have done it numerous times on my 500+ hp 800+ ft/lb duramax and the turbo is still in one piece. Diesels don't have a BOV so when you rapidly let off the throttle under high boost applications the turbines will rapidly slow down, causing the fluttering/barking sound.
Old Sep 15, 2008 | 10:36 AM
number1's Avatar
Turbo flutter is boosted air hitting your throttle plate while under load, then it reverses it self and travels back towards the compressor. When the pressure hits the turbo compressor, it rapidly slows the intake compressor down, causing a flutter sound. (Usually there is still high pressure in the exhaust manifold which can snap the turbine shaft.)
Wastegate flutter is caused when the exhaust gases start opening the wastegate, causing inconsistent boost, or boost spikes.
Neither are good.
Old Sep 15, 2008 | 10:41 AM
number1's Avatar
And one strong note for the diesel, it doesn't have a throttle plate to snap close and stop air from entering the engine. It uses fuel control to slow the engine, unlike a gasoline engine which uses air control.
Old Sep 15, 2008 | 10:11 PM
jchevy's Avatar
My car does this under low boost. Is this something I should be concerned about? Its the BOV making the noise, is this the same thing as turbo flutter like in that vid? The BOV is a tial 50mm
Old Sep 16, 2008 | 08:03 AM
number1's Avatar
What spring do you run in your tial?
Old Sep 16, 2008 | 09:55 PM
jchevy's Avatar
Im not sure which spring is in it. I got it used and its whatever was in there. They guy I got it from was only running like 5 PSI.
Old Sep 19, 2008 | 08:49 AM
number1's Avatar
Take it apart and check the color of the spring.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
