OEM 19x10 Silver C6 Rims All The Way Around!
BandDirector Blk98ZM6
09-13-2008, 09:43 PM
I FINALLY finished a project that has been a year in the making to piece the package together. It all started with the purchase of a mint stock set of OEM C6 rims for $200. Decided I didn't want the staggered 18/19 combo, sold the 18's, had to find a set of 19's for the same price I sold the 18's for. Bought a used pair of 275/30/19 Michelin Pilot Sport A/S tires off of eBay, had to wait 6 months before I found another used pair. Had to get chrome AR lugnuts as well as four 1.25" adapters/spacers. Then, have everything mounted and balanced. I did a test fit several months ago and posted a couple of pics, but I still wanted to swap over to EradiSpeed rotors and repaint my calipers. I FINALLY did everything I wanted to do and put them on this morning. I'm VERY happy with the results!
So this is what I have in a nutshell:
C6 OEM 19x10 Silver rims on all four corners
275/30/19 Michelin Pilot Sport A/S tires on all for corners
1.25" spacers/adapters on all 4 corners
Lowered w/Eibach Pro-Kit
http://www.ls1tech.com/forums/attachment.php?attachmentid=147280&d=1221336258
http://www.ls1tech.com/forums/attachment.php?attachmentid=147281&d=1221336258
Or, here are the links to the full size pics:
Injuneer
09-14-2008, 03:55 PM
I generally don't like the larger diameter wheels on the 4th Gens, but that is a very good looking setup. Larger brakes will be the final touch. Very good looking car.
slomarao
09-15-2008, 10:49 AM
+1 with above, nice.
shock6906
09-16-2008, 07:48 PM
It does look pretty good. It'd look even nicer, though it's probably not possible, if the front could be lowered just a touch. :cool:
09-19-2008, 04:06 PM
The front has dropped a little since I took these pics. I took these right afte I got it off the jack. For some reason, my Pro-Kit usually takes a couple of days for the front end to settle after I jack it up...it also didn't help that my driveway goes slightly up-hill, so I probably should have parked it facing the opposite direction to snap the pics...
