IPrice
09-11-2008, 01:23 AM
Ok, between working 60+ hours at one job and 10 at another job this past week, I've finally found time to test some of my junk.
Tried to follow Shoe's tutorial/how to's on his site.
I first tested the coil. His pic shows 8k Ohms. I got 6k...I'm thinking it would be much higher if it were no good???? Input??
Then I moved to the A B C D prongs on the ICM Plug.
C Checks out and has a good ground
A & D both had 11.63 vdc with KOEO
B carried a low of 1.44vdc and a high of 2.88 vdc while cranking.
I'm taking this info as "Harness and PCM Check good."
I ran the car for about 30 minutes, with the fan switch off so that the motor would heat up and the components would heat up faster. After the 30 or so minutes, the car started to want to die. I jumped in and footed it to where it would come back, but there was clearly an issue. I let it die and proceded to do Shoe's tests procedures again.
The results were the same. Although at one point I tested for spark on the plug wire and had nothing.....rechecked the prongs on the ICM since I thought that I might have bent them in excess with the DVM's prongs earlier. Bent them back, plugged it in and it started right up....coincidence? I don't know...
I let the car sit with fans on high and a Dyno style blower on the car for like 5 minutes.
The car started right up.
I'm feeling that the OPTI is getting this "heat soak" condition. But I'm not finding any loss of spark or anything when the car "heats up."
Its left me high and dry twice. Both of the last times I've driven it. Both times less than 5 minutes into the drive and a couple miles out. The most recent time was scary since it sat for almost a half hour before it would restart. And on that particular drive home, it was seriously lacking in "get up" power.
So, in the experience that everyone here has had with them, I'm really feeling like I need to make that purchase and get a new OPTI. Is there anyone or any reason that it could be something I'm not looking at??
It does have an aftermarket alarm. I don't know much about disconnecting it so....?....
The CEL light is also on and the condition was "multiple cylinder misfires" but I didn't get the actual P-Code from the AHole at "Scheckers..."
Thoughts??? ThePartsLadi on eBay is the way to go????? Should I revert to a non-vented if I do??? no??
Thanks,
Ivan
Thanks,
Ivan
