1997whitez28
09-01-2008, 04:53 PM
What is the max to lower the car with and without Longtubes. someone had a lowered camaro and it was nice it was prolly a 2" drop.
longtubes and lowering1997whitez28 09-01-2008, 04:53 PM What is the max to lower the car with and without Longtubes. someone had a lowered camaro and it was nice it was prolly a 2" drop. sn8ke eatr 09-01-2008, 04:58 PM well the clearance varies depending on what brand of longtube you choose. offhand i recall pacestter having one of the best ground clearnaces. i have pacestters on my car and theres plently of room, but my cars not lowered. i think 2 inches is starting to push it, and more and you might be limited to mid legnths but i could be wrong SStupid 09-02-2008, 02:41 AM I wouldn't drop your car at all if you install LTs. 1997whitez28 09-02-2008, 05:47 PM I hit a big object in the highway and now my passenger side unibody it smashed up and thank god the door closes good. Either drop it if it helps or put a body kit on it or bondo or even a new panel. I don't have a welder. Ta4life 09-02-2008, 06:16 PM My LPP headers clear great....id say 1.5- 2" would still be decent with them The_Bishop 09-02-2008, 06:26 PM Wait... What? If you bashed up the rocker panel, lowering the car will not help with that at all. TeamingTealZ28 09-02-2008, 06:35 PM Maybe...so its lower u cant see the damage? Green96Z 09-02-2008, 07:33 PM I hit a big object in the highway and now my passenger side unibody it smashed up and thank god the door closes good. Either drop it if it helps or put a body kit on it or bondo or even a new panel. I don't have a welder. So the actual body is messed up? :eek: Get that fixed. That said, my Kooks tuck up very nicely and my y-pipe still occasionally scrapes speed bumps at stock height. I wouldn't drop it at all. 1997whitez28 09-04-2008, 12:39 PM I think it would be cheaper if I lower it then fix the panel you can't see it unless its parked on a hill or if you bend down. they would have to take the door off and pull it out and out a new panel and im guessing $2000 but for now all I can afford is to lower it or bondo. 2000GTP 09-05-2008, 08:12 AM At stock ride height, I have a little less than a soda can distance from the headers to the pavement. Factor in a two inch drop on top of that and you can get a visual idea of what kind of clearance you are dealing with. People have done it, but you definitely have to mind your surroundings, otherwise you will be dragging and banging your exhaust real quick. maybe2fast 09-07-2008, 09:55 AM I scrap my pacesetters without being lowered... JMG97SS 09-07-2008, 11:16 AM I have hookers and theres no way Ill ever lower the car now. I was planning on it but I scrap now if Im not careful. SStupid 09-10-2008, 05:42 PM I think it would be cheaper if I lower it then fix the panel you can't see it unless its parked on a hill or if you bend down. they would have to take the door off and pull it out and out a new panel and im guessing $2000 but for now all I can afford is to lower it or bondo. I had a similar issue with my wife's Civic Si. They had to remove the door, the side window, and cut out the rocker panel piece that actually stretched from the front of the door to the back wheel, then paint the whole side of the car from the door backwards. It was a $3.5K job. http://i2.photobucket.com/albums/y10/sstupid/dent3.jpg 1997whitez28 09-13-2008, 12:24 AM Mine looks the same as that. My door closes good just the panel is shot. Thanks for the photo shows that you care lol. Mine is alittle bit steeper. I hope its not going to be that much :-( | ||
