is this an opti problem?
23tigga
08-27-2008, 02:13 PM
My car will just turn over but won't crank I checked to see if fuel was coming up through the lines and it was so I guessing that its not igniting i guess but could someone help me out because I planning on going through with the opti surgery in the morning
stvski80085
08-31-2008, 09:42 PM
Look for spark so you know thats good. What about your fuel filter?
stvski80085
08-31-2008, 09:44 PM
Just pull one plug and turn the motor over. You should get a spark if you holfd it near ground on the bolck or headers.
23tigga
09-03-2008, 07:07 PM
Sorry for the update been tied up but put the new opti on and still no results just turns over I can hear the fuel pump priming and just don't have no clue as to what it could be
brahm
09-04-2008, 08:51 PM
It could be ICM/COIL, Opti just passes the spark alone.. unplug your wire from the opti/coil, and replace it with a spark plug wire put a plug on the end, and ground it (lean it) against your block. Crank it and look for spark. If you have no spark out of the coil, then I'd look at replacing the coil or ICM (and or checking all the wires leading to them)
Injuneer
09-04-2008, 09:24 PM
Have you scanned it for codes?
IPrice
09-07-2008, 05:22 PM
How about going through some of Shoebox's "how to's?"
http://shbox.com/1/4th_gen_tech2.html#opti_test
Might be able to help diagnose before you keep throwing money at it.
-Ivan
