does a 1990 camaro rs have a cranksenser?
ghost stripes
08-22-2008, 01:31 PM
i was told it may need to be replaced and where is it located thanks
max_ta
08-29-2008, 10:00 PM
probably not uses hall effect in distributor don't think they came out until 97 could be wrong just trying to help
Injuneer
08-30-2008, 04:31 PM
Is the RS a V8 or a V6? Might not make a difference, because the Chilton's engine control diagrams for the 3.1LV6 and 305V8 do not show a crank sensor for either. As noted in the post above, the ECM can get the cam/crank position info from the distributor.
