Rear Bump Stops with Lowered Car
Techpriest
08-15-2008, 09:33 AM
While putting on my new springs and new shocks I noticed the rear bump stops are rotted or missing. The new ones should be here today.
The car is lowered about 1.5". When putting the stops on should I shave them, or leave them stock?
I thought I should shave them 1.5" to match the shorter springs, but it back axle will hit the underside of the car before contacting the stop, that's not a good idea.
Thanks!
Injuneer
08-15-2008, 06:53 PM
The bump stops prevent the chassis from slamming into the axle housings. Also prevents the shocks from over-compressing, which can damage the shocks. Good idea to have the bump stops, even if they are cut down slightly. But cutting them down 1.5" sounds excessive.
bluz28
08-15-2008, 06:55 PM
First if your car has the 1/2 inch bumpstop spacers in the rear remove them!Then try them first for a week or two stock . if you still think you really need to, cut 1/2 inch off then drive it for a week or two; but don't cut no more than 1 inch maximum , and only if you have the hard (light yellow)bumpstops ,not the soft(light brown) ones . I have the hard (light yellow) rear bumpstops on my car and have 1 inch cut off , but I also have air ride springs instead of coilsprings in the rear suspension and they don't bottom out a easy as the lowering springs I've had in my car before.
Techpriest
08-16-2008, 12:56 AM
I did not realize the colors meant anything, that's funny. I have one of each, hard and soft. I ordered 2 and that was what they gave me. They are on the car at full height and will try that for a while.
Thanks all!
bluz28
08-16-2008, 03:00 AM
I didn't either at first, not until I had several sets of the soft (light brown)bumpstops and the last set I bought were the hard(light yellow) bump stops. IMO, If you got them at a dealership in town I would go tell them you need to get two of the same either both soft or both hard, not both! :yes:
