94Z28KC4-GU5-PO5
08-13-2008, 11:01 PM
just wondering if with a 94z28 im SOL when it comes to a scan tool check or will some sort an adaptor like this http://shbox.com/1/xraycable.jpg work on my car?
thanks........
thanks........
1994 z28 OBD-1 scan tool check94Z28KC4-GU5-PO5 08-13-2008, 11:01 PM just wondering if with a 94z28 im SOL when it comes to a scan tool check or will some sort an adaptor like this http://shbox.com/1/xraycable.jpg work on my car? thanks........ 94Z28KC4-GU5-PO5 08-13-2008, 11:21 PM is my only option with a 94z28 to hook it up to a OBD1 scan tool like at a dealership? Injuneer 08-13-2008, 11:29 PM There are OBD-I scan tools available that will plug directly into the 12-pin OBD-I port on your 94. Only the 95's, with their oddball 16-pin OBD-II style ALDL connector, but an OBD-I PCM require an adapter plug, or jumpers as Shoebox shows in the link you posted. Auto X-Ray made a reasonably priced OBD-I scanner, and you can find them used for under $100. There's also the ScanMaster LT1 that wires directly to the ALDL connector data pin. Many of the newer OBD-II scanners are also OBD-I capable, with the correct cable. Actron makes a few. Auto X-Ray makes some. Then there's free software you can download: TTS DataMaster (free for first 20 uses) http://www.ttspowersystems.com/ FreeScan (free) http://www.andywhittaker.com/ Just get a cable from AKM Electronics. http://www.akmcables.com/ | ||
