L99 heads vs LS3/L92
jay_lt4
08-04-2008, 11:12 AM
the L92 and LS3 share the same head/port design, can we assume that the L99 heads will also be the same as the LS3/L92's
looking to have a set of heads ready to go for the new camaro
thanks
JasonD
08-04-2008, 11:19 AM
All right! Now we are talkin'! :cz28:
I don't know your answer, but it is about time people started planning cool stuff! Hopefully someone will chime in.
jay_lt4
08-04-2008, 07:23 PM
i know,, i wish there was a little more info about the L99 engine, most rumors are that it is the same engine as the LS3 but the block is designed for the AFM/DOD
so my plans are to have parts ready, some cnc heads, cam, and standard LS2/LS3 lifters and eliminating the AFM/DOD(as long as there is a programmer/tuning out for the car), and the usuall bolt on's
TrickStang37
08-04-2008, 09:48 PM
thanks
The L76 uses the same heads as well. And it too has AFM. the only major difference is the L76 is a 6.0 vs. 6.2.
If it shares the same valvetrain as the L76, which I think it will since it has AFM and is also limited to 6000 rpm, then cam may be a problem. It could result in valve float. Or, atleast, the longevity of the springs that would be put in to match whatever aftermarket cam is put in. The LS3 uses hollow sodium filled valves to offset some valvetrain weight since the valves are pretty massive. The L76, on the other hand, uses cheaper, solid valves since it's limited in RPM anyways and helps GM save on cost.
I can see the L99 having the same valvetrain as the L76.
jay_lt4
08-04-2008, 11:15 PM
that is why i will have a set of heads ready to go, along with a cam and standard lifters,, pretty much the same set up i have on my s-10 but the L92 heads will be cnc ported for the camaro,, my s-10 pulls hard to 7500 rpm with no issues of valve float
Big Als Z
08-05-2008, 12:23 AM
The L99 is an LS3 with AFM.
Thats it.
RobWilson
08-05-2008, 10:32 PM
Thats it.
Then why is the hp rating different? There must be some other difference....cam? tuning? compression?
TrickStang37
08-06-2008, 12:31 AM
the cam, lifters and tune are different.
the valvetrain is PROBABLY different.
SubSolar0
08-22-2008, 01:05 AM
I think the L99 also has variable valve timing technology too.
TrickStang37
08-22-2008, 01:38 AM
