S&W SFC and Torque Arm
sleeperLT1Z28
08-01-2008, 09:37 AM
Have any of you used this S&W Racecars subframe connector and torque arm kit:
[URL="http://www.swracecars.com/store/93-02-Camaro-/-Firebird-Bolt-On-Sub-Frame-Connectors-OSCARItem_71=40-610.aspx"]?
I like how it ties the front to the back, and also the floorpans and crossmember together. My only concern is driveshaft and exhaust clearance around the crossmember. My Pacesetter Y-Pipe tucks up nicely, but I would hate to spend all that money only to find that it hits. Also, I have a 3.5" diameter aluminum driveshaft, so that is another space consuming part.
Anyone have experience with this setup?
sleeperLT1Z28
09-04-2008, 03:04 PM
Anybody???
slowride94z
09-04-2008, 07:37 PM
http://www.swracecars.com/store/93-02-Camaro-/-Firebird-Bolt-On-Sub-Frame-Connectors-OSCARItem_71=40-610.aspx?
fixed your link
Green96Z
09-04-2008, 08:57 PM
It looks like you might have to drill into the subframe for that. The front mounts don't line up with existing holes in the front subframe. You can see where the holes are here:
http://marylandspeed.com/umi-performance-3point-subframe-connectors-boltin-19932002-camaro-firebird-umi-2004-p-1461.html
Bud M
09-06-2008, 02:05 AM
I like the general idea but it looks really under-engineeered. It's hard to tell with that crappy photo, but the brackets for the ds loop and cross brace look pretty flimsy.
You're gonna have to decide whether you want to be the guinea pig on this one. At that price, I'd pass.
slomarao
09-08-2008, 04:38 PM
go with someone proven, BMR, UMI, etc.
tomcowle
09-09-2008, 02:15 PM
Your kidding right??
Go to a NHRA event where Stock Eliminator is run and look under a few cars, I bet 1 out of 3 have this exact or same style set-up underneath it. These cars are killers in the 60-foot department too.
Call S&W and ask them your question.
Bud M
09-10-2008, 12:49 AM
No, I wasn't kidding. I'm not an engineer, but looking at the way the crossbar mounts onto what are basically single bolt pivots on the subframe connectors, same for the the ds loop, and the way the cross brace's body mounts and rear control arm mounts are made look crude to me. And it is a crappy photo.
Do YOU have these parts on your car?
tomcowle
09-10-2008, 07:39 AM
I have 2 F-bodies and YES one of them does have S&W parts on it, the car is not done however when its done having a substandard rear suspension set-up is the least of my concerns. I work on a 1998 firebird LT1 nhra legal stocker and we've been 1.2 sixty foots and ran 10.4 in legal trim.
My other F-body has all Edelbrock stuff under it (the same stuff everybody calls junk or says it doesn't work). It has been mid 1.5 sixty foots on motor (only 308 rwhp) and now 1.4 sixty foots on the hose
Bud M
09-10-2008, 11:13 AM
It sounds like you're evading the question. Do you have this subframe kit on your car? If so, how about some pics? If these are quality parts we'd all like have a look at them.
tomcowle
09-10-2008, 12:54 PM
As stated above, YES I have S&W suspension, subframe and every other part S&W sells for an F-body (except lower control arms). You can stop by my shop anytime after its done to inspect it yourself, or if you can wait until the car gets back from finish painted I'll snap you pictures and send them directly to you for your inspection and approval.
Or maybe you should take the initiative and contact S&W for specs and better images of it than to take my word for it?!
Bud M
09-10-2008, 07:58 PM
Don't get you panties in a wad, tomcowle. What you stated above is that one of your cars has S&W parts on it, not that you have these subframe connectors. How would I know what parts you have?
And why are you so worried about what I think about S&W products?
As for taking the initiative, its really up to the seller to convince me to buy their product, something that S&W's competitors do a much better job of. Ever see the photos on UMI/Spohn/BMR's websites? I don't have to guess how well their products are made, I can see for myself. Maybe S&W should take the initiative and get someone with a decent camera to take some decent photos and put them on a decent webpage with properly edited ad copy (like what is 1-1/2² x .120² wall steel tubing? My calculator comes up with 2.25 x .0144. I doubt they use that to make their SFCs) to showcase their products.
The original post asked if anyone has these parts. Why don't you just post your opinion and the OP can make his decision?
mdacton
09-10-2008, 08:15 PM
My buddies that run LT1 stockers all run it. They range from 1.29-1.27 60's
They system sure works good.
Go to class racer and ask...I bet 8 out of 10 use that exact system. And most will be in the low 1.30's......
I personally don't have the whole thing but a few things from S&W....they are great to deal with and most times I get my stuff within 2 days from them.
tomcowle
09-10-2008, 08:43 PM
BudM, unremarkable...
As per BudM request: SleeperZ, they are nice quality and "flimsy" is a highly inaccurate term for the product. They are more work and welding to install than most sfc's packages however the results speak for themselves. To answer part 2 of your question, I honestly don't know if you will have interference issues, the Stocker I work on has just collector extensions and no exhaust.
slowride94z
09-10-2008, 09:32 PM
are you talking about the same thing,? states no welding
http://i300.photobucket.com/albums/nn22/slowride94z/406102-1.jpg
Designed to be 100% bolt on for your 93-02 Camaro / Firebird coupe (does not fit convertible), this kit requires no welding and can be installed using hand tools. This kit also clears all stock exhaust components while closely following the floor pan contour assuring you a close fit and maximum ground clearance. This is the only kit on the market which ties the subframes, rockers and floor pan into one assembly! The included crossmember features a mount for S&W¹s adjustable torque arm which can be purchased separately and installed along with the subframe connectors and crossmember, or you can retain your O.E.M.torque arm and mount. The connectors and crossmember are fabricated from1-1/2² x .120² wall steel tubing and feature waterjet cut brackets for exact fit. These components are hand assembled on a custom welding fixture and MIG welded for high strength and ease of installation. All of the above components are powder coated black for a long lasting, durable and attractive finish.
"1-1/2² x .120² wall steel tubing " I mess with steel tubing and other ,Haven't seen it referred to like this
mdacton
09-11-2008, 08:44 AM
huh? Its pretty common in tubing I don't see whats not common about that.
sleeperLT1Z28
09-11-2008, 11:52 AM
I think what you are trying to say here is that you are concerned about the size and thickness of the tubing. My guess is that this setup uses smaller diameter and slightly thinner-walled tube because it has so many attachment points along its length. Most SFCs only go from the front to the back, with nothing in the middle, so they have to be thicker.
The main thing that I would like to know about here is y-pipe clearance. If anyone has a picture of this setup, I would really like to see it. Thanks for the good info you guys have provided me.
slowride94z
09-11-2008, 07:41 PM
1-1/2² x .120² Its the little twos that I haven't seen,what are they referring to 1 1/2 square tubing? the pictures look round
I googled it and that web page came up
bad95formula
10-09-2008, 02:18 PM
A buddy of mine has this kit in his 95 T/A and the kit works VERY well. I drove the car several times before and after the install and the kit made a huge difference! I'll be going with this kit when I finally get around to the chasis stiffening area of my project. I would definitely call S&W and talk to them yourself. They're very knowledgable and will answer any questions in great detail.
