95Blackhawk
08-01-2008, 12:40 AM
Hey all,
Just up front, I do know what I am doing in calibrating MAFs. I have done it for years and confirmed my prior Hawk engine, with its calibrated MAF, was correct. In that situation, I had to modify the MAF by -12% on the idle side to adding 9% more on the WOT side (meaning it was lean in WOT area before calibration). Reference this sticky to confirm my background: http://www.camaroz28.com/forums/showthread.php?t=505190
Here is the deal: my current RX7 conversion with the 95 LT1 setup shows the correct calibration requires a reduction of 28.5% from the stock tables to on the WOT end (100 AFGS and up) to get my BLM's to 128 range and eliminate the rich condition I had.
Bottom line, this does not seem right with a reduction of 28.5% in the tables! However the car runs fantastic and makes great power. Injector DC's are reading about where they should and further, the BLM's are equal on each bank. They only thing I can conclude is the heads are more efficient and thus burn more oxygen which shows up as a rich condition with the O2's. I had calibrated this MAF prior when the engine was still a 350 stock headed LT1 and the calibration at that time indicated a 9% reduction at WOT.
Just looking for input...
Ben
Ben
