DonutMachine
07-31-2008, 10:37 PM
98 Z28 looking for more brake power. I replace lines with Russell stainless steel kit. I want to do the Z51 conversion but after reading decided that I should upgrade to larger rotors but keep my stock calipers for budget reasons, will this be possible. I thinking this set up will work minus the calipers
C5 conversion bracket-
GM Part #
Quantity
Description
12530682
Right front caliper (standard C5)
12530683
Left front caliper (standard C5)
10445856
Right front rotor
10445857
Left front rotor
12455799
Pad abutment bracket
22163727
Front caliper brake hose
12530697
Pad abutment guide pin
12530703
Guide pin boot
22163795
Banjo bolt
10139097
Banjo bolt copper washers
GM Part #
Quantity
Description
12530682
12530683
10445856
Right front rotor
10445857
Left front rotor
12455799
22163727
12530697
12530703
Guide pin boot
22163795
Banjo bolt
10139097
