axehead
07-28-2008, 04:57 PM
after doing a search i see that i can buy a clutch assembly from the local parts store for about $200 & order a high performance disc (i'm looking at the mcleod single) from thunderracing or etc. i'll have 480rwhp, would my stock flywheel be ok?
thx
Green96Z
07-29-2008, 06:53 PM
Do you have a stock bottom end, or an internally balanced rotating assembly? If your bottom end is stock, then the stock flywheel should be fine. A steel flywheel is stronger and slightly lighter, and an aluminum one is a lot lighter, so it will help the engine spin up faster. The only problem with aftermarket flywheels is most of them are neutrally balanced, meaning for an internally balanced engine.
axehead
07-29-2008, 10:30 PM
i have a stock bottam end.
