pinion play
C5042081
07-28-2008, 03:28 PM
95 10bolt 2 series carrier
I am installing 4.10, The pinion bearing was pressed, crush sleve in, all new bearings/race , there is still play after tighten nut w/ washer.
Not sure what to do/look for I did use the stock shim
RUDEDOG
07-28-2008, 04:15 PM
There should be some play depending on the amount of backlash. If you still have play front to rear you haven't crushed the sleeve yet.
C5042081
07-28-2008, 05:24 PM
ya the play is from front to rear, i used a impact gun but didnt go to crazy, from what i read its bad to over tighten the nut.
Does it matter which way the crush sleeve goes on?
jay_lt4
07-28-2008, 09:57 PM
that is why it is called a crush sleeve
you need to keep tightening the pinion nut until you reach your pinion bearing pre-load, new bearings 25 inch pounds of rotating force, use a inch pound beam style torque wrench
you need a quality 1/2 impact gun and a little gear lube on the threads helps too
if you go past the desired pinion bearing pre-load, you will need to start over with a new crush sleeve, they are a 1 time use only
cause4panic
07-29-2008, 08:14 AM
Throw the damn cush sleeve away. They are not needed, complicate the install and did i say NOT NEEDED.
jay_lt4
07-29-2008, 10:14 AM
it is a very easy set up procedure to use a crush sleeve, and if you can not get the crush sleeve to work out you can use a solid pinion spacer (i use these on all high hp cars/trucks)
C5042081
07-29-2008, 04:24 PM
kool thanks for everyones help, I put some more tq to the bolt and it tightened fine, I didnt realize how much it took to crush the sleeve
