'83 Z-28 horn button
I need to remove the horn button from my '83 Z-28,but I don't know the correct procedure.It appears that it just twists off,but I don't want to force it. Any help or advice would be appreciated. Thank You
It just pulls off.
I believe the pad has 3 little spring steel pieces that hold it in the center of the wheel.
You'll need to pull between the wheel & the pad as you don't want to pull the soft part of the pad off it's backing.
Britt
Britt
Aaront810
Aug 29, 2020 09:34 PM
Sep 18, 2015 03:46 PM
