Do I need Limited Slip Additvie?
KITT3000
07-21-2008, 11:57 AM
I have a 1997 V6 with traction control. One wheel spins. I can't find anywhere in the maual that it says for me to put limited slip additive in the rearend.
Do I need to? If I don't, would it help if I did?
I have some rearend noise and I am doing this as a first step.
Thanks!
km9v
07-21-2008, 12:10 PM
Traction control is not limited slip diff. Trac. control uses ABS. You may or may not have a LSD.
KITT3000
07-21-2008, 04:21 PM
so I don't have to worry about the additive then right? What would happen if I put it in there?
shoebox
07-21-2008, 04:34 PM
Probably nothing.
Injuneer
07-21-2008, 06:27 PM
Look at your RPO build code tag for G80. That would indicate you have a limited slip differential.
