Connecting clutch mc to slave
blackbirdta
07-21-2008, 10:04 AM
This is for my '35 Ford coupe I am putting an LT1/T56 in. I have an aftermarket clutch mc/brake mc combo. The stock line pushes in and locks with a pin (line show in bottom in pic) was used to connect the clutch mc to the slave cylinder, but my new clutch mc requires the line to be screwed in to the back of the clutch mc.
the top line show in the pic is a braided line im using for the rear brakes (i just got it out to try and figure out how to do this). If i buy a new braided line i have the connection at the clutch mc figured out, but the slave I have still requires a line that pushes in and locks with a pin. Am I going to have to buy an aftermarket slave where the line screws in? do they even make them? or maybe there is a connection that is threaded on one end and pushes in on the other?? :confused: thanks
http://filebox.vt.edu/users/rtisch/master%20cylinder/IMG_2056.JPG
Injuneer
07-21-2008, 06:28 PM
Did you consider just using the stock LT1 clutch master cylinder? Or the McLeod "adjustable" version?
blackbirdta
07-21-2008, 08:29 PM
I did, but it's too late now...i already spent the $500 on this set up :(
since i wanted to mount the brake MC under the floor i decided i would rather have both pedals coming from under the floor instead of the brake under the floor and clutch swinging from the firewall.
is there any easy "fix" you can think of? how do other slave cylinders attach in other transmissions? Thanks
blackbirdta
07-30-2008, 08:43 PM
ttt once...still trying to figure it out :)
NJ-LE
07-30-2008, 09:03 PM
blackbirdta:
In case you haven't already, I'd suggest you call Earl's, Russell or Aeroquip and explain what you are trying to do. They may have the appropriate end fittings in house and can make up a line for your situation or supply a short line and transition adapter as a solution.
Good Luck with the project.
blackbirdta
08-06-2008, 09:41 AM
NJ-LE- i just saw your reply...do you have any more information for those companies as far as contact info or what exactly they do? thanks
Green96Z
08-06-2008, 11:30 AM
Those companies specialize in brake and clutch hoses.
http://www.russellperformance.com/
http://www.holley.com/index.asp?division=Earls
blackbirdta
08-07-2008, 09:31 AM
great...i'll check them out. thanks!
blackbirdta
08-27-2008, 08:03 AM
I was refered to McCleod...they have an AN to "roll pin" fitting for $44 that sounds like it should work for anyone else trying to do something similar.
