86Camarolt1
07-19-2008, 09:24 PM
Is anyone running a Inline fuel pump, would this work with the fpr
In-line fuel pump86Camarolt1 07-19-2008, 09:24 PM Is anyone running a Inline fuel pump, would this work with the fpr '94 Bad A Z28 07-20-2008, 09:20 AM The only thing to worry about with an inline pump is that it is restricted to what your in-tank can push... unless you eliminate your in-tank pump. Injuneer 07-20-2008, 11:37 AM Actually, since the in-tank pump and the inline pump are now sharing the "pressure" creation, they will both flow a greater amount than they would if an individual pump was the only source for pressure. But that's not a good way to increase flow. That's a good way to increase the pressure capability of the system. And if your in-tank pump is dying, or dead, it isn't going to work at all. And yes, the stock LT1 fuel pressure regulator can control a system consisting of a stock in-tank pump and an added inline pump. Why do you want to add an inline pump? I'll move this to the "Fuel and Ignition" forum...... 86Camarolt1 07-20-2008, 03:04 PM just was askin because my fuel pump is dying and I was trying to avoid dropping the tank. But I guess I will have to drop it afterall '94 Bad A Z28 07-20-2008, 11:45 PM But that's not a good way to increase flow. That's a good way to increase the pressure capability of the system. That's the point I was trying to get across. | ||
