Two-piece driveshaft
JakeRobb
07-19-2008, 04:14 PM
So I was looking at the technical cutaway renderings in the Gallery (http://www.camaroz28.com/gallery) area.
In particular, this picture:
http://www.camaroz28.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=883&g2_serialNumber=1
I'm pretty sure I see a two-piece driveshaft.
IIRC, the '04-06 GTO had a similar piece, and those guys had an awful time getting it to hold significant amounts of power. I read about some guys trying one-piece replacements and having major vibration issues.
Does anyone know what the reasoning behind a two-piece driveshaft is? Does it result in a more consistent pinion angle or something? Also, can anyone elaborate on the issues it had in the GTO?
4THGEN Z
07-19-2008, 08:42 PM
Isn't that a V6 drivetrain? The 4th gen V6 had a 2-piece DS as well.
bossco
07-20-2008, 12:55 AM
Gahhhh... well at least the F5 crowd will be able to get in on the new millenium replacement for UD pullies. The 2-piece DS in the Mustang is a major horsepower soaker-upper.
Ron78Z&01SS
07-20-2008, 01:17 AM
Looks like the V6 to me.
wbdigi.com
08-16-2008, 04:35 PM
shock6906
08-17-2008, 05:53 PM
I don't see why it matters. A two piece driveshaft sucks whether it's a V6 or a V8. My V6 has a 1 piece Z28 driveshaft now. If the one piece works without any other modification to the car, then what's the point? Certainly a once piece driveshaft must be easier and cheaper to engineer and produce. I can't see any reason to have a two piece if a one piece will work.
JakeRobb
08-18-2008, 12:00 PM
I think it helps to dampen vibrations.
shock6906
08-18-2008, 02:27 PM
As long as its balanced I'd imagine there wouldn't be too much problem. Yes, I know the steel one piece was a vibratin' mofo in many Camaros. The one I swapped into my V6 vibrates @ 55MPH. The one in my Z doesn't vibrate at all.
JakeRobb
08-18-2008, 05:05 PM
I guess not so much in the area of vibrations you feel -- more of the high-frequency stuff that you can only hear.
ws6transam
08-18-2008, 11:30 PM
A two-piece driveshaft with an intermediate bearing in the center enables you to have a higher critical speed rating on the driveshaft. Picture the driveshaft spinning at crazy-fast RPM's, then picture it starting to bend slightly in the middle, like a jump rope. The point where the driveshaft starts swinging like that jump rope is where the driveshaft reaches critical speed, and when that happens, you get vibrations galore, followed shortly by driveshaft failure. There are also oscillations at the harmonic frequencies associated with the critical speed RPM, and these are what you feel at lower speeds, such as 80 MPH+.
Engineers have to respect the driveshaft critical speed RPM when they design their drivetrain, and they try to move the critical speed RPM upwards by changing the diameter of the driveshaft, making it stiffer, or by making it shorter. The two-piece driveshaft is a method that is used to allow the driveshaft to spin faster with less oscillation. With the intermediate bearing, you in effect create a system of two smaller driveshafts, each of which have a higher critical speed than a long single driveshaft.
shock6906
08-19-2008, 06:02 PM
Ah, my lesson for the day. :)
5thGen
09-24-2008, 02:28 PM
IMHO it is a method that uses a trick that adds weight and complexity that can otherwise be done with better manufacturing techniques.
A high quality one piece aluminum shaft can be used, and after adding up the extra mount and bearings and joint, I wonder if it would be more expensive than 2 pieces in reality. I doubt it.
Regardless, I am sure some manufacturer out there will offer a one piece that will decrease powertrain loss and lower weight, both by a small margin.
diarmadhi
09-24-2008, 03:19 PM
These type of posts are exactly why I keep coming back here... Golden nuggets of information like this are worth it. I knew there was a purpose but to have the engineering answer to it is useful knowledge!
nelfastla
10-25-2008, 03:38 PM
I´m gonna change the 2 piece drive shaft (the bearing has broken) of my 97 V6 for a 1 piece LT1 drive shaft. Does this work needs a heavy mod or something? Or the swap is just like that, easy. Just take out and put on.:p
JasonD
10-25-2008, 08:25 PM
Try the 1967-2002 Specific Technical Discussion / Drivetrain (http://www.camaroz28.com/forums/forumdisplay.php?f=44) forum for that one.
