NJ-LE
07-18-2008, 01:20 PM
I have the parts for the C5 Vette front brake upgrade and would like to upgrade the rears too.
Other threads have said that the LS1 rears have slightly longer axles (~1/4") and these are required if LS1 rear brakes are to installed on a 1995 housing.
I came across the following at the Moser Engineering website and this seems to say that LT1 and LS1 rears actually have the same length axles.
A102805
APPLICATION: Fits 1993-newer Camaro and Trans Am W/3-Channel ABS 10 Bolt Chevy rear, 28 spline, 32" long Diag. 235/120
A102806
APPLICATION: Fits 1993-newer Camaro and Trans Am W/4-Channel ABS 10 Bolt Chevy rear 28 spline, 32" Long Diag. 290/147.50
If they are, then it appears I wouldn't need new axles. Is this true? (I have to draw the line somewhere!!!)
If true, what else is necessary? Calipers, rotors, mounting brackets and cables. All the cables? Would I also need a box full of e-brake parts or would they be part of the caliper package?
I believe what's been written ... that the rear upgrade is not nearly as useful as the fronts. But since I'll be changing hoses and flushing now's the time. However if the cost begins to approach that of the front (axles & hundreds in e-brake parts too) I won't do it. By the way, this will be all new parts.
I've looked online but haven't been able to find a diagram or blow-up of the LS1 rear brake setup.
A102805
A102806
