Bassani exhaust
TBSPW
07-16-2008, 10:05 AM
I was over on LMperformance and i saw the Bassani true dual exhaust with the x pipe...right now i have the slp loudmouth system and i was thinkin about switching...just wondering if its worth the price and if it would perform and sound better than what i have now.
'94 Bad A Z28
07-16-2008, 01:47 PM
It will definitely sound better than what you have now. From your signature it doesn't look like you have much done to your car so I don't know that the current single exhaust system you have now is much of a restriction for you at this time. In fact a basically stock car like yours might lose power from a single exhaust to a true dual set up.
If I remember correctly Bassani's true duals run along the passanger side of the car and go over the axle side by side. If you really want true duals at one point I would suggest making your own custom setup. It will be cheaper and you'll be happier with it.
