JL 500/1 amp not powering on...
Old Jul 14, 2008 | 01:06 AM
chesee48's Avatar
Car has been sitting awhile, so i did need to jump the car...however when i drove it around i noticed the subs werent working....When i went to check the amp, i saw that the green light is not on, along with all the other lights on the amp...
anyone know whats likely the problem?
thanks!
Old Jul 14, 2008 | 03:13 AM
chet's Avatar
check the fuse or the remote turn on lead
Old Jul 14, 2008 | 07:13 AM
JakeRobb's Avatar
Super Moderator
If both of those are fine, then make sure that your power and ground cables to the amp are both making good connections.
If all four of those things are good, then the amp is bad.
Old Jul 14, 2008 | 09:40 AM
PentaVolvo's Avatar
basically check fuse under hood and at amp, a voltmeter is helpful
if you need troubleshooting help im in the NW suburbs near woodfield mall and more then willing to help ya out
NewsBot
Jan 8, 2015 11:29 PM
MJ_Z28
Aug 8, 2002 09:02 PM
Omega9
Aug 2, 2002 12:33 AM
Snake Slayer
Jul 29, 2002 12:39 PM
