drperformance
06-28-2008, 08:21 PM
I have a 1995 383 13:1 compression LT1 with a direct port nitrous system in a 87 firebird and everything was tuned to run at 50 psi. I run a progressively controlled 200 shot in 2nd and 3rd gear.
Last month at the track my car was falling on its face at the top of first gear after a couple of passes. So I tried to adjust my aeromotive AFPR and the pressure was acting weird would not adjust up and was around 40 psi with the vacuum line off when it was set at 50 psi? So I decieded it was time to upgrade the stock 24 lb injectors for some 36 lb SVOs and I replaced the Aromotive AFPR (JUNK) with a vacuum regulated holley. And I put the car on a dyno and tuned everything in and it was running great.
Went to the track today and after a few runs I developed some breaking up in second gear? I know it is a fuel issue, so I pop the hood to add 2 lbs of fuel with the AFPR and to my suprise it did the same thing, I pulled the vacuum line and it was flucuating around 40 psi when it was set at 50 with the line off?? And when I went to adjust it it would not adjust up. So I let the car set and cool for 15 minutes or so and then checked the pressure and it was 5 psi higher, could it be a heat soak issue with the 255lph intake pump?
I then drove the car home which is a half hour drive at 70 mph, where it bucked and studered at first which I related it to the inconsistent fuel pressure. But the further I drove the smother it got and when I got home I poped the hood and checked the fuel pressure and it was right where it should be 50 psi whith the vacuum line off? Do I have a failing pump?
By the way the car put down 375 rwhp and 385 rwtq and I am running a -6 feed line and a -4 return.
