panhead 06-25-2008, 01:04 AM where is the fuel filter on a 1994 camaro Z28?
i want to try and replace it myself... am i better off spending the extra $20 to have an oil change shop change it?
is there a brand of filter thats recomended by you guys to get? also is there a brand to avoid?
Thanks a bunch!!!!!!!!!!!!
MIKE
shoebox 06-25-2008, 08:48 AM http://shbox.com/1/fuel_filter.html
You can't go wrong with an AC-Delco filter.
Casie 06-26-2008, 02:55 PM It should be underneath on the driverside between the door and the rear tire.
I have a 95 Z28 and they did not make much changes between the two years.
They are pretty easy to change out yourself. It should not take more than 5 to 10 minutes. Just be carefull when you remove the fuel lines because the residule fuel will drain out, so you may want to have a small plastic bowl when you change it out.
Fatdog2 06-29-2008, 11:59 PM Don't forget to loosen the gas cap.:)
Red Devil 99' 06-30-2008, 12:12 AM holy crap are you serious?
you don't know where your fuel filter is?
wow wut a noob!!!!
lol
the answer is yes under the rear passenger seat on the driver side. follow the fuel lines along the car and it's the small can in the line.
every f-body 93-02 fuel filter is pretty much the same and in the same location.
make sure your prepared it's going to spit gas at you.
IPrice 06-30-2008, 12:56 AM holy crap are you serious?
wow wut a noob!!!!
lol
Vent the pressure slightly prior to removal by opening the gas cap.....key off engine off of course.
Two 17mm wrenches will make light work out of it.
Good luck and don't worry about comments from the likes of fellas with "GlowShift Triple Gauge Pods".....: :):D:eek:
Dig!,
Ivan
Red Devil 99' 07-02-2008, 01:34 AM Vent the pressure slightly prior to removal by opening the gas cap.....key off engine off of course.
Dig!,
Ivan
yeah like he said
yes I am :nuts:
( gots nuthin but pos feedback on my install they look great)
http://i279.photobucket.com/albums/kk144/AmericanMuscleV8/0531081126-2.jpg
http://i279.photobucket.com/albums/kk144/AmericanMuscleV8/DSC01546.jpg
Injuneer 07-04-2008, 12:29 AM Yep... but why rag on a guy who asks a question you happen to know the answer to. Not very friendly. We all had to start somewhere.
Red Devil 99' 07-18-2008, 01:55 PM everyones allowed to be a smart ass relax
Injuneer 07-18-2008, 06:41 PM everyones allowed to be a smart ass relax
Ohhhh?
43 posts and you're already the "expert".
If you have a problem with a moderator, please follow the guidelines, and take it up in a PM, not in the thread.
Have a nice day.
Gord's Green Z28 07-18-2008, 10:21 PM Definitely use a line wrench (aka flare nut wrench). Using a regular wrench, it's too easy to wreck things.
If you don't have access to a lift or pit, I'd just get a shop to change it. Getting gas all over your face, eyes, arms....it's not fun.
A shop would take maybe 10 minutes to do it. It's not going to cost a lot to have done.
n2ceptor 07-19-2008, 12:41 PM everyones allowed to be a smart ass relax
And people like this is why others don't want to make a post looking for answers, because they might get ridiculed.....
No question is stupid or foolish, just been asked a thousand times in the past, as we all have had to ask at one time or another.....:)
bones95 07-22-2008, 03:30 PM Make sure you bleed off the pressure at the fuel rail and remove the fuel cap. Should be very little fuel drain when removing the filter.
Red Devil 99' 10-09-2008, 04:31 PM even with a smart ass answer i do believe I helped answer the question...
McLovin 10-09-2008, 08:37 PM Ohhhh?
Have a nice day.
Sure he is, arnt all ls1 owners. :lol:
shoebox 10-09-2008, 11:38 PM even with a smart ass answer i do believe I helped answer the question...
The question was answered in the first reply. ;)
Injuneer 10-10-2008, 12:28 AM even with a smart ass answer i do believe I helped answer the question...
If you want to argue about this, take it to a PM.... don't continue the issue in the thread. Like being a smart ass, arguing isn't the way to handle it.
Red Devil 99' 10-10-2008, 10:50 AM ............
