pianoman35
06-22-2008, 01:23 AM
Nothing comes out when I try to use my washer fluid, and I cant really tell if its a blockage or I need a new pump. Is there any way to test it? Thanks.
any way to test washer fluid pump?pianoman35 06-22-2008, 01:23 AM Nothing comes out when I try to use my washer fluid, and I cant really tell if its a blockage or I need a new pump. Is there any way to test it? Thanks. Injuneer 06-22-2008, 11:19 AM Connect 12V and ground directly to the pump and see if it runs. mdacton 06-22-2008, 11:24 AM the little nozzles stop up easy. you can clean them with the thing you use to clean cutting tips for a torch.....or just get new ones. Z28SORR 06-23-2008, 02:18 PM Or a piece of wire. | ||
