95 Z28 Bad Head Gasket & Input Shaft Bearing
I'm trying to sell my 1995 Camaro Z28 Convertible. It's an LT1 with a 6 speed manual with the hurst shifter. White car with a white convertible top and a gray interior. Seats are in great shape. Body is in great shape. Now for the bad. Car has a blown Head Gasket. Started running rough and i found some oil in the cooling system. Input shart bearing in the manual trans just started to chatter as well. Now for the good. LT4 intake and knock module tuned by pcm's for less. Just passed NJ inspection. All street legal parts. Has 1.6 full roller rockers, double valve springs, Moroso electric water pump, msd coil, new moroso wires and NGK tr55 plugs, new 02 sensors, coolant temp sensor, intake air temp sensor, functional ram air hood with a just cleaned K&N filter. Mid length hooker headers to a high flow cat and a flowmaster with quad tips, all 2.5 inch. 3.42 rear gears. stock suspension. Needs the head gasket and a Input shaft bearing in the trans. Ran 13.6 at raceway park with a terrible launch. Capable of 13 flat. Never over heated. never ran dry on oil. Driven only three blocks after the head gasket blew. I'd fix it but i just don't have a place to do it. lost my garage. Looking for $2300. drop me a line if your intrested.
