Stock Manifold Down Pipe (Y-pipe) Stud...
euforia51
06-08-2008, 01:47 PM
'97 Trans Am. Anyone know if it's a screw in or is it pressed in? I had to cut one of them off last night. Thinking of drilling it out and just putting a bolt/nut in there but if I can easily get the remaining piece of the stud out, I'd rather replace it. It is the driver's side. Thanks!
MARKTHOMASBRAND
06-08-2008, 05:03 PM
They are screwed in.I snapped one of mine when replacing the y-pipe/ cat.
I drilled it out and replaced it with a stainless nut and bolt.
Start off with a small drill and work your way up :)
Regards,Mark.
euforia51
06-08-2008, 08:14 PM
Thanks very much. That's probably what'll end up doing. It's so rusted, it probably won't come out anyway.
MARKTHOMASBRAND
06-08-2008, 08:27 PM
I tried some vice grips first but it wouldn't budge.Use a drill bit about 2-3mm diameter first and go all the way through,small drills are much easier to centre.If you try using something like a 10mm drill bit to start with it will just skid off.Make sure you wear some safety goggles unless you like burning your eyes out with hot swarf :p.
The studs are pretty soft,you should have no trouble drilling it out.Good luck :).
