1988 iroc-z/28 LSx 6.0L swap WITH TILT TRAILER FOR SALE!
1SLOSBC
06-01-2008, 10:18 PM
located in pensacola, FL 32514
1988 cheverlot camaro iroc-z28.
2004 6.0L with patriot heads.
ported victor jr.
1" HVH super sucker billet spacer.
235 237 599 602 112+2 futral custom cam.
harland sharp rebuilt rockers.
stainless 1 3/4 long tubes. 3" y pipe to 4" exhaust.
750 quick fuel drag carb. billet electric pump.
all braided line and a/n fittings.
msd 6010 box, complete with wiring harness and 7550 box to tune, or CD for custom laptop tuning.
ls1 radiator and ls1 dual fans.
big ass permacool tranny cooler with fan.
optima battery.
PTC full forward pattern manual th350. built to the extreme. 36 element sprag, heavy duty drum, etc....
yank 5000 stall race converter.
HD steel driveshaft.
moser 9"
4.33 richmond gear. yes it whines.. you can still hear the radio and talk. dont worry.
detroit true trac posi mounted in a stock HD iron case.
full tubular suspension, k member. coilovers. pinto rack and pinion.
strange 10 way struts/shocks all the way around.
1" ST sway bar. spohn torque arm.
spohn wonderbar in front.
spohn sperical bearing caster/camber plates.
aerospace brakes all 4 corners.
weld magnum drag 2.0's all the way around.
28" sportsman fronts.
28" hoosier drag radials out back.
car will come with a nitrous plate system, with a lot of goodies. missing some pipe/an fittings to be complete. full standalone fuel system as well.
car was painted in 2003 dark shadow grey. it was stripped, done right. all body panels, emblems, stripping, parts removed for paint.
SS hood.
undercarriage of car is competely painted black with epoxy paint.
4th gen camaro dash and console. all factory gauges are in working condition. all of them....... wideband in a/c vent, along with a raptor shiftlight.
2002 trans am leather seats front and rear. full working power drivers seat. have been redone, without the plastics on the back.
car has 5 way race harness in front, no factory belts, front or rear.
all new weatherstripping. new carpet. new floor mats. new hood struts. new(er) hatch struts.
power windows, tilt steering.
cruise, a/c, heat, and power locks have been removed. horn does not work due to previous owner.
power hatch pop still functions.
interior is EXTREMELY CLEAN. no junk, broken or cracked parts.
its all COMPLETE. no missing pieces. even the under the dash hush panels are there.
dome light, cig lighter IS fucntional.
NO ROLL CAGE. will need one to be NHRA legal.
all front and rear signals function, car has working delay wipers.
so many extras i cant name them. i have a shop FULLLLLLLLL! of parts i will include with car. extra body kit, interior pieces, exterior pieces, electrical parts. bolts, nuts, washers. hard to find parts.
6 factory 16" iroc wheels. 2 fronts and 4 rears.
sooooo sooooo sooo many mods done to this car. the only thing that is stock is the taillights, steering column and headlight/taillight harness.
its ALL been modified in some shape form or fashion.
car is consistant at the track and drives suprisingly well for the setup.
2005 model mule tuff 25 ft total 18ft tilt trailer included.
2" ball. new chains, all new LED lighting, wiring. painted black. deck is wood, and now painted black as well.
new black steel spoke wheels with new cooper 225/70/15 tires. factory gm center caps and lugs. looks real trick.
make a great track/bracket car/heads up car.
pretty consistant runner.
5 passes last time out range from 6.901 to 6.908.
car runs 99mph+ 1/8 mile. ALL MOTOR. 6.20/6.30's with nitrous should not be too hard.
1.51x short times all night if the track is there. 1.53x if its off.
car should be close to 3160 with current mods. last time it was scaled it was 3260. CAR ONLY.
the car is beautiful inside and out.
SERIOUS INTEREST ONLY. NO TIRE KICKERS. DO NOT WASTE MY TIME.
CLEAR FLORIDA TITLE IN HAND.
any questions, ask. any specific pics, i can usually get them snapped and posted within 24 hours.
$$$$$$$$18,000.00 for car AND trailer. will deliver within 200 miles.
I WILL NOT SEPERATE CAR OR TRAILER.
I WILL NOT PART THE CAR. DONT ASK.
NO LOWBALL OFFERS. AGAIN, DO NOT WASTE MY TIME.
if you laugh at the price or think im crazy, then you have no idea what goes into buying and building a car. you never get what you put in them, nor do i think i will, or i would price it close to 30K.
show me something that looks better and is faster for cheaper and ill tell you to go buy it.
1slosbc@cox.net
http://i102.photobucket.com/albums/m108/stage20/DSCN0952.jpg
http://i102.photobucket.com/albums/m108/stage20/DSCN0951.jpg
http://i102.photobucket.com/albums/m108/stage20/IMG_9879_Small.jpg
http://i102.photobucket.com/albums/m108/stage20/DSCN1018.jpg
http://i102.photobucket.com/albums/m108/stage20/DSCN0963.jpg
http://i102.photobucket.com/albums/m108/stage20/Mar0410.jpg
http://i102.photobucket.com/albums/m108/stage20/Mar0409.jpg
http://i102.photobucket.com/albums/m108/stage20/DSCN0659.jpg
