Saturn Sky now a plug in electric.
Old May 28, 2008 | 03:13 PM
indieaz's Avatar
http://www.triplepundit.com/pages/te...com-003181.php
http://www.ampmotorworks.com/index.html
Electrics are slowly becoming more reasonable in price, performance and range.
Old May 28, 2008 | 03:23 PM
onebadponcho's Avatar
It looks like it would take about 10 years to offset the initial cost of the car with the amount of fuel savings, or likely even less time given the rising fuel prices.
Old May 28, 2008 | 03:58 PM
indieaz's Avatar
Right, I'm not sure the batteries will even last 10 years (even if they do, i suspect yoru range would be well under 150 miles). The problem is this company has to buy these vehicles from GM (probably for the same price you or I pay) an dthen go through all the work of removing the engine and installing the electric powertrain. I think this proves GM could probably do this and sell the vehicle for a lot less than this third party company is doing.
Old May 28, 2008 | 04:51 PM
DvBoard's Avatar
People do similar to the pirus which increases the electric only range and allows plug in's. If manufactures could do this it would save the inital cost of the engine and serveral components. However do realise that to be like this from the factory it would have to be tested and proven to be reliable over several years as well as safe. No one thinks twice when a modded electric car breaks, but it would be big(er) news if factory ones have major flaws.
Old May 28, 2008 | 05:12 PM
mdenz3's Avatar
Now that's an electric car that I might consider if I had the $$$.
Old May 28, 2008 | 05:35 PM
Eric Bryant's Avatar
A range of 150 miles would require a pack with a usable capacity of at least 24kWh (based upon the assumption that this vehicle could achieve an excellent and nearly unrealistic figure of 10 km/kWh; the much smaller and lighter Tesla roadster is actually about 10% less efficient than this). You'll need to provide a pack that's substantially larger than the required usable capacity; typically, the pack has a total rated capacity that's around twice the usable capacity (this not only allows for degradation of the pack over time, but also allows the pack to avoid full charges and discharges). Figure that a pack of ~48kWh is required (for reference, the Tesla pack is sized at about 50kWh, and requires the use of about 90% of that to achieve its claimed 220 miles).
The currently accepted cost for an automotive-grade lithium-ion pack is about $1300/kWh. This brings us to a pack cost of about $63,000 if indeed it's sized to 2x the required usable capacity.
How AMP is providing a conversion for only $25,000 is a bit of a mystery. It could be that the pack is undersized, and maybe it isn't built to OEM standards. More information from AMP would be useful.
Old May 28, 2008 | 06:22 PM
unvc92camarors's Avatar
Cool to hear it get some news. This is actually being done right next to the city I live in.
Old May 29, 2008 | 08:49 AM
Geoff Chadwick's Avatar
I strongly doubt they took that route. Call it an educated guess, but like you said - the numbers dont add up.
Also to consider is that its supposed range is roughly 66% of the Tesla - which has a 900lb battery pack.
A 600lb battery pack - for both weight *and* volume would be hard pressed to stuff into a sky as well. If that means splitting it in half with one chunk under the hood and the other where the tank would go - thats more engineering involved.
Also, the pictures on their website all show a sky with a standard exhaust tip. I'd have figured that would be gone... Kinda makes you wonder about the company...
Old May 29, 2008 | 09:55 AM
jrp4uc's Avatar
All the pictures I saw had no tail pipe. The flash on the homepage shows multiple views including the rear with no exhaust and license plate "0 TL PIPE."
Anyhow, it's interesting but I wonder about how safe the batteries are in an accident. At least with a major manufacturer I'd feel more at ease about that aspect.
Old May 29, 2008 | 10:18 AM
Looked through it again... I coulda sworn the flash showed quite a few without it as you went around the site... Anyway...
And the battery is under the hood, with smaller individual motors at each wheel - literally - at each wheel. I wonder what that would do for reciprocating mass and suspension rates, not to mention how the motors would stand up to excess vibration.
Old May 29, 2008 | 11:13 AM
jg95z28's Avatar
FWIW, Most cutting edge electric/hybrid car designs are using motors at each wheel. They can provide braking by running in reverse.
Old May 29, 2008 | 11:48 AM
graham's Avatar
So its the price of a Sky plus $25,000?
Old May 29, 2008 | 12:53 PM
HAZ-Matt's Avatar
Basically.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
Xiantyl
Jul 21, 2015 05:42 AM
Jul 17, 2015 02:47 PM
Boss002
Jul 9, 2015 03:33 PM
