94Hawk148
05-27-2008, 06:30 PM
I have a '95 Formula w/out a cat-con.
Can I tweak the programming w/ TunerCat to get it lean enough to pass on the Dyno, or will I be forced to install a cat-con?
I have the EGR disabled, and the air pump disabled, but they are still on the car... so it will pass the visual test.
The engine is basically stock w/ stock manifolds, cam, etc. All I need is ideas on what tables to tweak to get it to pass. If I can weld an empty cat-con on the car and load an "emissions" program, I'll be set.
Any ideas?
Any ideas?
