WHIPLASH
05-27-2008, 08:38 AM
The cam is sold.
Mild LS1 Cam For SaleWHIPLASH 05-27-2008, 08:38 AM The cam is sold. jp2002ls1 05-27-2008, 04:53 PM Tempting.... If only it were slightly bigger. What valve springs do you run with that cam? WHIPLASH 05-27-2008, 06:41 PM I used comp 918's. Now, I use Patriots because I have their heads. SSpdDmon 05-27-2008, 07:24 PM So very tempting!!! AL SS590 M6 05-28-2008, 07:29 AM Tempting.... If only it were slightly bigger. What valve springs do you run with that cam? Put it in with some 1.8 rockers. It will act a little bigger. WHIPLASH 05-28-2008, 07:52 AM This is a bit bigger than the 02 ZO6 cam Duration@.050: 205* intake, 219* exhaust Lift: 0.551 intake, 0.547 exhaust LSA: 117.4 SSpdDmon 05-28-2008, 03:41 PM Any idea what kind of power this cam will make on my car? Currently running a D1SC pushing ~7psi (stock engine w/ dual patriot springs) through a good sized exhaust. I'm assuming I'd lose a little boost after the install, right? WHIPLASH 05-28-2008, 03:49 PM You know what, I gained 8 rwhp over the Lingenfelter GT2-3 that is pretty known for its street manners and for blower cars. I did loose about 2 lbs of boost, but that was a simple fix..... smaller pulley. Hard to say what you'll gain I went 424 to 432 then pullied up to 464. I'd say 30+ rwhp once you get your boost back up. Hope that helped a little. PhantomTA 05-30-2008, 10:15 AM Any idea what kind of power this cam will make on my car? Currently running a D1SC pushing ~7psi (stock engine w/ dual patriot springs) through a good sized exhaust. I'm assuming I'd lose a little boost after the install, right? itl be a decent power gain down low and in the mid range and allow you to run more rpm at the previous boost level. Id say about 20-30hp if you keep the pulley you have on now. Id lose the patriot low end springs and maybe use a manley spring. I know a company that sells better ones but they do not sponsor this site. WHIPLASH 06-02-2008, 06:38 AM The cam is sold. Thanks | ||
