STS95T/A
05-26-2008, 02:13 PM
here is a list of everything i can think of, if you need anything not listed feel free to pm me
complete lt1 with all accessories, wireing and pcm out of a 94 camaro z28 with 120k miles-$1100 picked up
94 a4 LT1 tranny-$250 picked up
323 Rear end-$250 picked up
Camaro LT1 headlight bar-$80
LT1 dual fan assembly-$80
LS1 dual fan assembly-$80
LT1 thick core radiator-$80
95-98 V6 A4 radiator-$50
LT1 A4 radiator-$70
Maroon Camaro manual doors ( driver's side has a crack in the fiberglass in the door jam, it is not that bad but is there)-$100 picked up for the pair
Dark gray complete seat belts-$50 front and rear
Red Camaro Z28 hatch-$50 picked up
Red Camaro Rear bumper-$50
Red Camaro beager panel-$40
Black Camaro beager panel-$40
LT1 Camaro tail lights-$25 each
Salad shooter center caps-$5 each
Hatch release button-$5
LT1 Camaro fog lights-$20 each
electric Red firebird/ Trans Am mirrors-$25 each
Dual horn assembly-$25 with pigtails
93-96 Camaro headlight control panel-$20
93-96 Camaro HVAC control panel-$25
Grey seatbelt loops-$10 pair
Triangle mirror cover pieces-$5 each
93-96 Camaro 150 mph guage cluster (147 k)-$40
93-96 Camaro 110 mph guage cluster(124 k)-$25
98-02 Firebird 125 mph gauge cluster(125 k i think but am not 100%)-$30
Firebird A4 T handle shifter-$10
A4 Shifter assembly all cables-$40
LT1 steering column w/ key-$60
93-96 Camaro CD player-$50
93-96 Camaro cassette player-$25
Black 93-02 Firebird/Trans Am tail lights center piece-$20
93-95 firebird/trans am dash-$80
96-02 firebird/trans am dash in grey-$80
LT1 stock K member-$40 picked up
93-96 camaro driver side air bag-$40
93-97 power steering rack-$40
93-97 passanger air bag-$30
98-02 passanger air bag-$30
LT1 stock valve covers-$25
LT1 stock roller lifters-$25 set (16)
LT1 stock timing cam gear-$20
LT1 stock timing chain-$20
LT1 stock rockers-$25 set (16)
LT1 stock push rods-$20 set (16)
A4 pedal assembly-$40
LT1 E brake cables-$30 set (3)
LT1 brake master cylinder-$15
LT1 stock cam-$20
E-brake handle assembly-$20
LT1 water pump-$30
96/97 V6 starter-$30
T-top divider (on roof)-$25
rear view mirror-$20
tan dome light-$5
grey dome light-$5
black camaro power side mirrors-$20 each
98 air bag sensor-$20
93-95 air bag sensor set(3)-$20
Spare tire jack and wrench set-$20
stock steel torque arm-$20
stock A4 steel drive shaft-$30
Tan t-tops shades-$30 pair
LT1 complete front spindles-$25 each
T56 stock shifter assembly-$20
T56 Lt1 stock clutch basket-$40 picked up
93-97 Camaro front silver fenders (need paint)-$40 each
98-02 Burnt Orange Formula front end conversion (including : front fenders , bumper , hood, headlights, bumper support , and mounting brackets)-$450 for everything
93-97 White firebird hood-$40
93-97 white firebird hatch-$50
black Z28 hatch-$50
Red firebird hatch-$50
red firebird rear bumper-$40
LT1 dip stick and tube-$15
93-97 camaro/firebird fuse cover (under hood)-$10
stock rear LCAs-$20 pair
stock lower a-arms-$15 each
stock LT1 3 chanel rear axles-$25 each
stock LT1 rear backing plates-$40 pair
93-97 V6 273 rear end w/ drum brakes-$80 picked up
LT1 stock heater lines-$25 set
Stock salad shooters (4) with bald tires-$100 picked up
all prices are obo and without shipping
i'm located in mansfield tx 76063
thanks
robbie
LT1 A4 radiator-$70
LT1 stock cam-$20
LT1 water pump-$30
tan dome light-$5
grey dome light-$5
black Z28 hatch-$50
thanks
robbie
