C5 Corvette wheels and tires, local to New Baltimore, MI ONLY
fryguy
05-26-2008, 12:24 AM
03 Corvette stock wheels and tires, great shape and low milage. $650, will not ship, local only.
Click here for pics:
http://detroitracing.net/forums/showthread.php?t=6111
Black Sunshine/ 00SS
05-26-2008, 09:01 AM
Will these fit a 2000 Z28? Are they 17, or 19? What size are the tires.
jp2002ls1
05-26-2008, 10:31 AM
They will fit a 2000 Z28 but have a slightly different offest than stock. The fronts should be 17x8.5 and the rears should be 18x9.5.
05-26-2008, 02:28 PM
So, they are 17's, or 18's? With the offset being different, will they rub, or stick out?
jp2002ls1
05-26-2008, 05:16 PM
If they are stock the the difference in offset will cause them to stick inward slightly and may rub on the inner fenderwells in the back, most people run a 1/4" spacer to correct the offset. The front 2 rims are 17" and the rear 2 rims are 18".
fryguy
05-31-2008, 06:25 AM
They look great on an F-body. I was going to use these but I ended up going with a narrowed 9" and drag wheels.
