Manual Valve Body, No Electronics 4L60E
c0rey
05-16-2008, 10:27 AM
Im doing a conversion to a 5.3 controlled by ems pro and have no way to electronically control my transmission. I talked to the local tranny guy about putting a trans go Stick type shift kit in it that takes out all the electronic shifting. So i can live with a shifting car, He told me that he would need to put a vaccum modulator on there since when the electronics are disconnected it causes the pump to run max psi and I would burn up the pump. Also how can I control the lockup feature(thinking toggle?). Dont want tci tranny control or any of the others.
Performabuilt
05-16-2008, 10:38 AM
He is correct on the vac mod when using that kit and yes you can set up the lockup on a toggle switch
