Trying to locate strange oil leak?
Rich92RS
05-13-2008, 11:31 AM
A couple days ago my car started leaking oil more than it use to (leaks just alittle bit from the timing cover); but now it leaks a pretty good amount under the motor. I backed it out of the garage, and it left a trail of oil drops. I put a drain pan under the car to catch the oil drops and to see where it was leaking from but I cant tell. I coasted the car down, then started it to pull it into the garage. This time though there was no oil drops. :confused: The oil is dripping off two, things. Its traveling onto the plastic torque converter cover, and dripping off from there. Its also dripping off the bottom of the oil filter.
Ive got the plenum moved out of the way, and the distributor out to get a better look. The rtv sealant on the back of the manifold is oily. Everything above the oil sending unit is dry, and pretty much everything from the manifold gasket below is oily.
Now I guess it could be the intake gasket, but I don't think it would be this big of a leak; would it? I also read about to much crankcase pressure or something, so I checked for any open bolt holes and I found one. My PCV rattles so I guess its fine? Its right above the oil filter on the block. Anyone know if a bolt goes it there? Heres a pic of what I'm talking about. Maybe I have two leaks? Any ideas?
http://i197.photobucket.com/albums/aa267/Rich_86IROCZ/Oil%20leak/oilhole.jpg
TPeye
05-13-2008, 12:43 PM
I just fixed a similar problem on my '92. I would bet that the intake manifold is leaking. New gaskets and good bead of RTV along the china walls should take care of it.
Rich92RS
05-13-2008, 02:15 PM
Would yours leak about 15secs after starting it? I installed the distributor, started it up and during the 1-2mins I had it running I got a small sized pancake circle of oil.
AutoRoc
05-13-2008, 11:43 PM
Everything below the oil sensor is wet....leading me to believe that the oil sensor may be cracked.
