84devilz
05-13-2008, 09:29 AM
I have an 84 Z28 5.0L i have just installed a new cam lifters, gear to gear
timing , intake and carb and vacum advance distributor. My question is
since i dropped the oil pan down to install the timing cover the oil pan is leaking. I do not want to remove or lift the engine (doing it in
my driveway) has anyone replaced the oil pan gasket without lifting or
removing the engine?? and if so any tips would be welcome.And should i use a 1 piece gasket ??
