JoeSpeed
05-11-2008, 01:41 PM
Power window recently stopped working on my 95 Trans Am.
It started by making a popping or clunking noise when the window was going up. This happened a few times then one time it stopped about 2 inches from the top and just started making a grinding noise similar to the headlights when the plastic gears wear out. I can roll the window down fine, but it won't go up. I can pull the window up manually without resistance almost to the top, but it falls back down when I let it go. You definetly can hear the window motor working, but it sounds like it's grinding on something.
I was hoping someone might know what this is. I'd like to get the parts before I rip apart the car. The previous owner said the window motors were replaced about 2 years ago. It's too bad because the window used to move quite fast for an F-Body.
Thanks in advance for your help!
