alternator
midnightnavyz28
05-09-2008, 09:15 PM
i need a new alernator for my 2000 z28.....
im running a new duralast gold battery....
jl audio a1200 monoblock around 250x1 @ 4ohms & jl audio a4300 4 channel amps 75x4w rms @ 4ohm
its professionally installed, no short cuts....hundreds in wiring & accessories alone.....what a good alternator that will keep my damn lights from blinking at night?
PentaVolvo
05-10-2008, 12:51 PM
clearly the professionall installer didnt do the Big 3 because with a stock alternator and big 3 you should have no dimming at all
bluz28
05-10-2008, 06:35 PM
If you have installed a underdrive crank pulley that could be your problem also. If so, install a overdrive alt pulley. And also upgrade to larger alt and battery cables, both +pos. and -Neg.
THE_RUCKUS
05-14-2008, 12:15 AM
wouldn't a smaller alt pulley make the alt spin faster, thus providing more power?
Angelis83LT
05-14-2008, 01:50 AM
An alt can only put out so much power. the windings decide how much it puts out. Who did you have professionally install it? I have two amps running a little more than yours and I never see a problem with lights blinking and I have a stock 3rd gen alt.
