Torque Arm question?
Old May 7, 2008 | 09:49 PM
rexcellent's Avatar
I just finished installing my new tunnel mounted umi torque arm tonight and I am pretty impressed. I did not notice any ill effects over stock other than slightly more vibration which I can understand. The question I have is, which angle is positive and which angle is negative. Right now I have a total angle of about 1-1.5 degrees between the rearend and the driveshaft. That is, if the rearend is at 0, the front of the driveshaft is pointing down.
Is this negative or positive?
I hear the best setting is around 1-2 degrees negative? Am I already there or am I on the opposite side of things?
Old May 8, 2008 | 09:27 AM
Z-RATED94's Avatar
If your calculations are correct, and you were reading the angle finder the right way, you got it. The only reason I mention this is because I screwed it up the first time trying to read the angle finder.
Old May 8, 2008 | 10:13 AM
Wild Willy's Avatar
The nose, front of the diff should be down relative to the driveshaft by just a degree or two- under heavy acceleration, it will torque up slightly and be in-line-
Easy to adjust on ramps, you can experiment a little and tune it- it really depends on how hard you are accelerating, versus how much time you spend cruising- Took me a couple tries to get mine dialed in right. Nice to not be putting that load into the tail end of the tranny, too-
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
