How much more do I need to run High 12's
fastdan
05-07-2008, 03:49 PM
I have a 93 Z28 with a 96 Trans Am Engine only 30,000 miles.
It's an A4.
My Mods are:
K&N Cone filter
Hooker Long Tube Headers
No Cats
True dual 3 inch Exhaust
3000 Stall Torque Convertor
Ecu I think. My car shifts at around 6000
3:23 Stock Rear
CSR Electric Water Pump
Removed Egr and Emissions
TB Bypass
Slight weight reduction
I never actually ran the car.
Let me know what you think.
Thanks,
Dan
tomcowle
05-07-2008, 03:58 PM
3.73's and a good tune and you'll be flying.
LSWHO
05-07-2008, 05:15 PM
With drag radials you might do it now.
Otherwise I'd agree with above.
rock1501
05-08-2008, 12:04 AM
I agree I ran 12.52 with what you have and et streets and 373 gears
CamaroRacing12
05-08-2008, 12:22 AM
if u have sticky tires ur in the 12's
AL SS590 M6
05-08-2008, 07:28 AM
I agree.
JakeRobb
05-08-2008, 07:50 AM
Practice, guys. He'll need practice. :)
Z-RATED94
05-08-2008, 10:20 AM
What brand converter? As far as sticky tires, try a set of MT street radials. I think you'll like em.
northdakota93z28
05-08-2008, 01:04 PM
skip 12's run a 150 shot!!!
CamaroRacing12
05-08-2008, 02:26 PM
yea u wont get 12's first pass... but after a few trips to the track with sticky tires u will be in the 12's
AL SS590 M6
05-09-2008, 08:11 AM
Oh come on Jake it's an automatic. A4 + sticky tires = no practice necessary. Heat the tires up, stage, stab the gas, stop and collect 12 second time slip.
slomarao
05-09-2008, 01:39 PM
you should be able to get there with what you have provided you cut good 60ft times. If you cant 60ft now you ll b able to with a set of dr's.
The 3.73's will get you there even if you 60's suck.
What kind of weight reduction? How much? Getting your race weight down will help everything out across the broad.
