Red93Camaro
05-01-2008, 10:12 PM
The Blinker thing on the left of your steering wheel/ cruise control / wiper fluid etc...idk what its called...BUT those all work except The windshield wiper part, I twist it towards me and every speed doesnt work but the HI speed... Is there some kind of little computer in there I need? or something? What do I need fixed, cause I need that ASAP
Thanks for the help!
TheZ_project
05-01-2008, 10:30 PM
It is probably the wiper motor not the combination switch/multi switch. Check the wiper motor connector to see if power is being supplied to the low speed side when you have the switch set to low speed.
Red93Camaro
05-01-2008, 10:45 PM
Its shot the previous owner said ...so Its the whole motor itself?
Red93Camaro
05-02-2008, 01:27 PM
So all I need is a new windshield wiper motor? to get all the speeds? or something else.
ss.slp.ls1
05-02-2008, 02:59 PM
When you turn the twist it, but not all the way to high speed, do the wipers lift up an inch and stay there, and then go back down when you twist it back off?
shoebox
05-02-2008, 05:29 PM
It could be the switch inside the column, too.
Red93Camaro
05-02-2008, 06:26 PM
no they dont move at all...They only move on the Hi speed...and they make a weird clicking noise I think the wipers are loose.
