scof0elife
04-29-2008, 12:06 AM
I removed a system from my car that I just sold, the system was already in there when I bought it. I'm planning to put it in my SS. Below is a picture of what I have. I will post the specs of the AMP's also below.
I am a complete noob when it comes to audio stuff so I need your help. I'm surprised I could not find a complete write up with pictures on how to install a system for our cars (unless there is one?). I'm looking for a Aftermarket CD Deck and I'm low on funds and would like for you guys to recommend me one. Also with wires, which one's do I need? I am planning to buy a box for those speakers. I'm still not sure if those are 10" or 12", need to messure them.
How much do you think I will end up spending to complete my system?
First AMP screwed into the box is a:
P MILLER RSA150.2HC
-Amplifier Type Dual Channel
-Bridgable Bridgable
-RMS Power at 4 Ohms 150 W x 2
-RMS Power at 2 Ohms 220 W x 2
-Performance
-Frequency Response 20 Hz - 20000 Hz
-Signal to Noise Ratio 90 dB
-THD at Rated RMS Power 0.1 %
-Crossover / Equalizer
-Bass Boost With Bass Boost
-Other Features
-Input Voltage 10.5 volt
-Dimensions
-Width 9.75 in.
-Depth 20.1 in.
-Height 2.25 in.
Small AMP is a:
Alpine Flex 4
MAX POWER (EIAJ)
75W x 4 (4 Ohm Stereo) 180W x 2 (Bridged 4 Ohm)
FEATURES
RMS Continuous Power (Watt) (at 14.4V, 20-20 kHz): 4 Ohm Stereo (0.08% THD) 30W x 4; 2 Ohm Stereo (0.3% THD) 40W x 4; Bridged 4 Ohm (0.3% THD) 80W x 2
The speakers are BAZOOKA
P MILLER RSA150.2HC
-Performance
-Other Features
-Dimensions
-Width 9.75 in.
-Depth 20.1 in.
-Height 2.25 in.
Small AMP is a:
Alpine Flex 4
MAX POWER (EIAJ)
FEATURES
